New rear bumper for Rooies.
niclemaitre
Town: Stellenbosch
Vehicle: 99 IFS DC 4x4
Real Name: Nic
Post by niclemaitre »
The 30 year old stock rear bumper on Rooies was very tired and rusty. It also had no way to use it for recoveries. I was beginning to become worried that a trailer might break the hitch point off. So it was time for a new one.
With some input from my engineering mates I designed a new one that has recover points, is directly inline with the chassis rails and looks somewhat stock.
Stress caluculations
10mm plate laser cut by TFD in Strand.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
niclemaitre
Town: Stellenbosch
Real Name: Nic
Re: New rear bumper for Rooies.
Cut the holes in the rear valance and test fitted the new brackets.
Test fitting and tacking the tubes. Going to need to move the number plate...
Also got some 3x38x76mm channel to add support inside the chassis rails.
Happy trails
Nic
IFS '99 DC "Benny"
niclemaitre
Town: Stellenbosch
Real Name: Nic
And done.
Happy trails
Nic
IFS '99 DC "Benny"
coetzer94
Town: Pretoorsdorp
Vehicle: Silver Hilux DC 2.8 GD-6 2016
Real Name: Vian
Post by coetzer94 »
Looking good!!
coetzer94
Town: Pretoorsdorp
Real Name: Vian
Post by coetzer94 »
What load did you apply for the stress analysis?
Post by Mars »
Very neat. How are the pipes attached to the brackets?
niclemaitre
Town: Stellenbosch
Real Name: Nic
I don't know what load was applied for the stress analysis, I can find out it you want though.
The pipes were (badly) fillet welded to the tubes. I suck at fillet welds, but I can use a grinder
Happy trails
Nic
IFS '99 DC "Benny"
Post by Mars »
:laugh2:
You know what they say. "If you need to grind your welds then your'e a grinder not a welder!"
Still looks good though.
coetzer94
Town: Pretoorsdorp
Real Name: Vian
Post by coetzer94 »
It would be a interesting discussion topic: Do these recovery holes take into account the load of the vehicle as well as the forces experienced during a recovery?
Lets say for a recovery the forces are 3x the weight of the vehicle (sucking thumb here) and add to that a safety factor of 2?
Your calcs should look something like this:
Vehicle 2000kg
Dynamic weight during a recovery: (x3) 6000kg
Safety factor of 2: 12 000kg
you can halve that value if you recover from 2 point at once, but for peace of mind i would analyse them for the total load on a single point.
I'm not sure about any of these numbers, but its just to get the conversation started?
niclemaitre
Town: Stellenbosch
Real Name: Nic
You're not actually moving the weight of the vehicle, you're overcoming the friction between the surface and the vehicle, so it's a bit more complicated than that.
Anyway, these are mounted far more securely than the old one was. The bumper itself is attached to the channel and chassis rail with two M12 grade 8.8 bolts (normal recovery points are two M10 bolts). The channel is attached to the chassis rail with one M14 8.8 bolt right through the top and bottom of the chassis rail and another M10 8.8 bolt through the top of the chassis rail.
Happy trails
Nic
IFS '99 DC "Benny"
