Hi There
I am in process of installing 2 Engel 40L fridges in the back of my Hilux. What I need advise on is the following:
From where can I draw power to both the fridges that will be situated at the back of the load bin? I.e Can the power be directly connected to the battery or should I install the solenoid ( hope it is spelled correctly) ?
I am absolutely clueless when it comes to electrical stuff.
I also need to get power to my tow bar to connect my caravan with a Brad Harrison connection.
Any advise would e highly appreciated.
Regards
Advice needed
Re: Advice needed
Caravan should ideally have it's own battery. A 2nd or even a third battery should be fitted in the bakkie to run two fridges, the main battery is not enough to run even one fridge continuously - you should look at solar panels to charge your additional batteries.
There are a number of threads here that cover the different options, just search for "dual battery" or "2nd battery".
- Vehicle: Hilux SFA
- Real Name: Rodney
Re: Advice needed
go to 4x4 direct for advise.
- Vehicle: Hilux 3.0 d4d D/C Legend 45 Auto 4x4
- Real Name: Jozua
Re: Advice needed
Thank you very much Guys.
I will go the 4x4 direct route, I do not want to mess up my bakkie
