Hi everyone my kzte 3.0 is using oil and have a power loss so, i asked on hilux4x4 what my problem could be and the one guy said it could be the top or the turbo. So i decided to begin by the turbo as it is less work and more cheaper than to start by the top. And the top was replaced 2 years ago, So i took the turbo of and saw there was oil from the turbo to intake manifold , so i read on the internet that its normal for a little bit of oil to be there is that true or false. But since the turbo is out would you guys recommend that the turbo be redone while its out
Thank you
regards Johan
Oil inside the Intake manifold
- Town: Caledon
- Vehicle: Toyota
Re: Oil inside the Intake manifold
That was me, Johan, and yes, a small amount of oil (very light coating) can be considered as being normal on an older motor. If it's more than a light amount, then I would say have the turbo done while it's out.
Let me also say that I'm not a mechie, but that I have looked after and maintained my own vehicles for the past 40 plus years (I'm starting to get a bit lazy in my older years). I have a fair mechanical knowledge and have never owned or worked on diesels but understand them fairly well. I say this so that you can weigh up my advice against what you might hear from someone else.
My advice to you was in light of the unusual oil consumption you are experiencing and as I said previously, the turbo seals was one of the possibilities. I still believe that's the most likely suspect. I'm not entirely convinced that this will be the only reason for the power loss but you might be lucky and find that the power is significantly improved after having the turbo done. (I would also try cleaning the injectors with a fuel additive). Otherwise you might have to look at taking the injectors out and having those checked, serviced and calibrated as well. (I assume that you have been replacing the diesel filters regularly as per service interval recommendations). If you're still down on power after that then I think the next step would be to look at the diesel pump, but that's one of the last things to my mind.
The thing I understand about diesels is that they are generally reliable and low maintenance until they get old. Then they start costing a lot to maintain / repair. It's one of the main reasons why I'm not a diesel fan and prefer petrol engines.
Hope the turbo overhaul solves your problems.
- Town: Caledon
- Vehicle: Toyota
Hey thank you verry much i appreciate your opinion and its sounds like you know your way around cars have a great day further
Regards johan
Regards johan
- Town: Caledon
- Vehicle: Toyota
Yes the bakkie went in for he's service every 10000kms
No probs. Let us know how you progress and what your experiences are along the way. Always nice to have feedback and I'm sure it will help someone else somewhere along the line.
- Town: Midrand
- Real Name: Nishan
Welcome to the forum.
Wiggle the turbo shaft and check for any play. Also look for scoring on the inside of the housing.
If there is a fair amount of oil then I suggest you send it in for the seals. The turbo shop will advise on whether anything else needs to be done. If you in GP I suggest you chat to Gabby at Fastec. Very friendly and knowledgeable guy.
I agree with Mud Dog on injectors and diesel pump.
Pop in a bottle of Wynns Diesel Injector Cleaner on a 1/4 tank of fuel and take it for a nice highway cruise to clean out the injectors. Its the easiest and cheapest thing to start with. (Make sure its the Diesel one and not petrol)
I'm not sure on the KZTE but on the D4D the diesel filter sits in a housing. What the dealers do is open it, drain the fuel and fill it with injector cleaner and run the vehicle for a while. Its a concentrated injector cleaner fix.
Oh, and replace the diesel filter if you have not already done so.
Does the vehicle smoke?
Real drivers use three pedals
