Good day
I have an Toyota 1989 4x4 2.2 and I replaced the clutch and am still struggling to get gears, the master and slave was replaced but no success
Please assist
Gear selection problem
Re: Gear selection problem
I replaced my slafe a while ago and it did not want to work. When bleeding I pressed the pedal in slowly, then keep it down for a couple of seconds, release and press in slowly again. Only after about 15 times doing this the pressure started to build up.
When bleeding with the normal pumping action it did not work.
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
Is the fork straight.Beast73 wrote:Good day
Please assist
Does is also struggle to find gears with the engine switched off when it's stationary?
Sent from my ELE-L29 using Tapatalk
- Vehicle: Hilux SFA
- Real Name: Rodney
sometimes extending the slave push rod does help buy just cutting a blot about 10mm longer then round it off both ends and try.
- Bear
- Real Name: Ricky
Hi Riaan
There could be many problems to that. It will be about trial and error.
Make sure that the correct gear oil is used as well as there is no history provided for the vehicle.
EP 90 GL has been discontinued and many people suggest wrong oils including the agents. The later model use different oils. The equivalent I found – Shell Spirax S2 G 80W-90 GL5 – API GL4
Transmission uses about 3.9L and transfer 1.6L – total 5.5 liters
If you are changing the oils, I suggest to let the oil drain overnight for the last drop to drain.
