A HILUX IS REBORN..... the itch!!!!!!!
- Musselcracker
- Vehicle: 1989 SFA D/C
Re: A HILUX IS REBORN
sorry for the ignorance what are we looking at here
- dustbuster
- Town: Richards Bay
- Vehicle: Rebuilding 91 D/C Hilux Mboza Body, OME 4Y EFI, & 91 S/C 4Y Hilux
- Real Name: Dean
the last photo was the backing plate for the drum brakes and the drive shaft that goes in the axle housing, the thing with the studs is the bearing housing that bolt onto the axle you can see the cir-clip and the bearing retainer
- Musselcracker
so what are your thoughts/options on the bullbar?
- Musselcracker
sorry for the all the posts... while you have got the axle off and in pieces why dont you try upgrade the brakes.... put on KZTE disc's calipers and brake booster!! (i could be corrected!)
- dustbuster
- Real Name: Dean
Still want to design an ARB style bumper and get one made just no time at the moment that is cosmetic stuff want to get the Hilux running then start on the interior, then exterior. Was thinking of upgrading the brakes as well but just to much on my hands think the standard breaks will be fine for now if they are fixed up and working properly, can be a project for the future also cant splash out to much with the bucks every thing adds up quickly especially getting tools to do the job. Back doors are at mboza so they can use them to line up the glass ones, once the project is finish will post up all the left over parts and see who wants what
- dustbuster
- Real Name: Dean
My first big ooopppps and surely not the last, the galv wash did not work and the primer is not sticking to the chassis :evil: :evil: so have to take it all off and try something else. What a waist of time now it is going to take another 2 nights to clean it up………… Toyota doesn’t have a gasket in stock for the back axle so going to have use gasket maker.
- Musselcracker
oh no dude..... not ideal pal!!
To paint, one should use an etch primer first (preferably not a water based one) like red oxide or otherwise a zinc chromate or calcium plumbate primer.
- dustbuster
- Real Name: Dean
used the galv wash and washed the chassis and used a balck etch primer still did not stickMud Dog wrote:To paint, one should use an etch primer first (preferably not a water based one) like red oxide or otherwise a zinc chromate or calcium plumbate primer.
going to try a little section with stone chip leave it over night and see if that works.
- dustbuster
- Real Name: Dean
Took the diff off last night looks in good nik cleaned the flanges going to go see if I can get new studs, washers and nuts later the one stud has been hit by a rock so cant reuse it luckily I could get it out. Got the side shafts back with the new bearings pressed on so tonight I will start putting it all back together.
- dustbuster
- Real Name: Dean
IT’S GOT WHEELS……………..
I put the new OME suspension on had some issues look here if u haven’t read it viewtopic.php?f=3&t=19883" onclick="window.open(this.href);return false;
Sorry for jumping all over the place, still need to make a plan with the back shocks as they are the wrong ones :evil: :evil: and will have no luck with SA4x4 store.
The chassis is really high as there is no weight on it cant even get the front shocks into the mounts will have to get the engine in place to bolt them on.
The paint is still a mess up used a galvanizer primer and then painted chassis black over it and it has nearly been a week and it is still tacky when u touch it and it scrapes off. :evil: :evil: :evil:
Next on the list is the steering started cleaning all the ball joints and tie rod ends
- Musselcracker
Re: A HILUX IS REBORN..... ITS GOT WHEELS
Nice work ...
Thanks for the pics of your steering arm... now I know what the inside of the thing looks like!
Mine is pretty shot! let me know where you get new parts like the rubber and springs
Have you tried tightening yours?Musselcracker wrote:Nice work ...
- dustbuster
- Real Name: Dean
Chris I am just cleaning mine up the rubber boots are still good, just going to get new grease nipples have painted it with hammerite will have more photos next week cant work this weekend going hunting with some matesMusselcracker wrote:Nice work ...
- dustbuster
- Real Name: Dean
- Musselcracker
i have tightened by adjusting screw on the steering box... well i was a bit nervous to tighten it too tight! whats a good gauge as to it being tight enough? i do not have a big jack or jackstands so the car has to sit on the ground!
i loosened the nut until the a bit of steering fluid leaked out and then tighten the screw!! and tightened the nut back again
I'm not refering to your steering boxMusselcracker wrote:i have tightened by adjusting screw on the steering box... well i was a bit nervous to tighten it too tight! whats a good gauge as to it being tight enough? i do not have a big jack or jackstands so the car has to sit on the ground!
I'm referring to the drag link in this picture...
Chris, what Cassie means is that you can tighten up the end screws on the drag link ... that compresses the spring and puts more pressure on the little cups, taking up the excessive play in the link itself.
Yebo yesMud Dog wrote:Chris, what Cassie means is that you can tighten up the end screws on the drag link ... that compresses the spring and puts more pressure on the little cups, taking up the excessive play in the link itself.
- Musselcracker
shot okes....
Should have read this on the weekend and could have fixed it! I know the screw you are talking about there is a split pin in there you have to pull off first!
Sorry did not mean to highjack your thread Dean!
- dustbuster
- Real Name: Dean
Update time, have put the drive chain on……………….. did some work on the engine replace the gaskets on the sump and tappet covers painted them as well also replaced the sparkplug tubes still lots to do now I am waiting for the bodie to be made.........
- NardusJVR
- Town: Louis Trichardt
- Vehicle: hilux 2.8TD
- Real Name: Nardus
dean............ Wel done. Stil some work left but she will look Gr8
- Musselcracker
put a seat on and drive it just like that!!
WOOOHOOO
WOOOHOOO
- Musselcracker
OKay whats been happening??
GIVE US AN UPDATE
GIVE US AN UPDATE
- dustbuster
- Real Name: Dean
Re: A HILUX IS REBORN..... THE WAITING GAME!!!!!!!!!!
The waiting game have paid for my body over 9 months ago and still waiting :evil: :evil: :evil: :evil:
Mboza is been taking there time hope it is worth the wait……………………
everything is ready for the body want to start putting it back together!!!!!!!!
- 519franco
- Town: Richards bay
- Vehicle: 87 Hilux 3L v6 Ford
- Real Name: Franco
go take a turn there when i was there i saw one hilux but wasnt getting worked on.. but i could be mistaken
FORD> Full Off Road Damnation
Sponser: MY DAD
- dustbuster
- Real Name: Dean
they have started on the cab waititng for some pics to be sent to see the progress am going to go down next weekend and have a look.519franco wrote:go take a turn there when i was there i saw one hilux but wasnt getting worked on.. but i could be mistaken
- dustbuster
- Real Name: Dean
So on Saturday went to Mboza and had a chat with Steve and showed me the new way he is putting the body together as to make it line up better, He is assembling the floor on the chassis and then putting the cab on top and lining it up and glassing in position.
I am going to cut my old cab up and reuse the front section and mounting plates/gusset which he will acid clean and glass into the new body.
Here are the pics of the my cab in the mold and some pic’s of Marks CAB getting fitted to the chassis
here is Marks cab
here is Marks cab
- Town: Gordons Bay
- Real Name: Luke
Aaarg!!! Drool drool, My cab's starting to look more like that, about 10% being fiberglass and the rest... painted rust :evil: .Hopefully as i add more and more fiberglass one day ill eventually have an Mboza body.
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
This is a gr8 thread........
Can we have an update????
[rimg=206x128]
[rimg=206x128]
- Town: Kuilsriver
- Vehicle: Hilux 2.2 DC 1989
- dustbuster
- Real Name: Dean
The body is coming together slowly, here some pics I took a two weeks ago when I was in Durban, The doors still need to be glassed onto the frames and the bonnet put together the inside skin and bar for the dash, also the floor needs to be reinforced.
Still lots to do
Still lots to do
- Quintin
- Town: Umhlanga
- Vehicle: Toyota Hilux D/C 2 x Diff lock, 33" MT Tyre, Lexus V8, Winch, Bull Bar and Tow bar.
- Real Name: Quintin
This is a very cool project keep sending those pics I am very interested in the progress as I am considering the same. If I may ask what is the cost of the cab.
Toyota Fortuner 3.0 D 4 D 4X4 A/T (4 play). Hilux DC 4x4, Lexus 4Lt V8, Mikhem suspension met 50mm lift, 50 mm body lift, Bilstein Shocks extra length, 33" tyre, 8 J rims, 2 x Lockers, Snorkel. (Blou Job) en dan n Peugeot 107 (Quickie).
Are those inner door frames metal? They don't appear to be F/G...
- dustbuster
- Real Name: Dean
Ya they are trying out a new way on the doors Steve is reusing the inner panel he plasma cuts the old outer skin off then acid cleans and electroplates the old inner panel (that is what you see) he is then bonding the fibreglass outside shell onto the inner.
Steve always says he has had trouble with the doors sealing and the windows ect. Now everything lines up and you can reuse all the bolt holes. He also does the same in the front for the lights and radiator that panel is steel as well.
We tried a new system with my cab as well where I cut all the brackets that mount the cab onto the chassis and he glassed them into the cab so it mounts better onto the chassis.
Here some pics of the parts i cut off my old body
- dustbuster
- Real Name: Dean
quintin best to call steve at mboza and ask him is number is zero84548637sevenQuintin wrote:This is a very cool project keep sending those pics I am very interested in the progress as I am considering the same. If I may ask what is the cost of the cab.
- Quintin
- Town: Umhlanga
Thanks That is what I will do. Your project looks very nice.
- dustbuster
- Real Name: Dean
was at MBOZA on SAT morning and got a few pics they are finished all the glass work
and now just the fulling and sanding left the a coat or two of primer and the shell should be ready for me to take.
so hopefully if all goes to plan i should get it by the end of next week
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
- MariusF
- Vehicle: Toyota Fortuner 3.0
- Real Name: Marius
I think it is time to show us the progress.
Feels like the waiting game is on us....Why are we waiting ?
- dustbuster
- Real Name: Dean
eish just no time!!!!! to busy with work CAB is ready just have to get from durban to richards bay will start work on it in the new year......
- dustbuster
- Real Name: Dean
So this weekend I got my birthday present!!!!!
next year is going to be a busy one!!!!!!! :alvarin: :alvarin: :alvarin: :alvarin:
Re: A HILUX IS REBORN..... the itch!!!!!!!
This is going to be a worthwhile read! Please keep your camera fully charged. ;)
- Baasvark
- Town: Virginia
- Real Name: Shane
You definately have"Beeg Cohones" to tackle a job like that!!!
I have had a similar itch once or twice but decided to play it safe and save up for another hilux ;)
- dustbuster
- Real Name: Dean
Eish have to get back into this project
just bought a house so been spending time sorting that out gardens are a mission
want to take the body home so I can work on it there but only got a single garage so will be a squeeze
will start this weekend so Monday will post some more pics of the Mbosa body
- dustbuster
- Real Name: Dean
So the project has taken a turn , think I am just going to get frustrated keeping the 4Y even if I EFI it . Just want the power to cruise to Transkei and places not battle up hills fully loaded. Also might get a boat in the future so want to tow as well.
So going to take the 4y out and do a Mazda/Ford WL2.5 TDI conversion with 33’ tyres and 50mm body lift, this seems to be the best motor option sucks that it is not a Toyota engine but fit’s as easily and not break the bank.
I like the fact the WL2.5 is a simple mechanical engine as well so no ECU needed so will be more reliable once set up, and double the torque than the 4y.
Started work on the CAB lot's of finishing off needed tiding up the glass few air pockets under gel coat and cracks on some of the joins noting to major, else looking good.
sorry didn’t get time to take some decent pics
under cab glassed in steel rib from cab
crack in door pillar
- Froll
- Town: Vioolsdrift
- Real Name: Roger
- Club VHF Licence: N/A
Massive job you are doing there Dean. I am reading the post with interest and was wondering if you have got any further?
- MOFASA
- Real Name: Johno
An update would be awsum.....
[rimg=206x128]
[rimg=206x128]
- dustbuster
- Real Name: Dean
Engine is ready Hoppy should courier it up this week , so need to take the 4Y out,
The body is not lining up nicely on the chassis so bit of work needs to be done there
and the mounts are going to have to be custom heights to get the body level.
Then I want to spray in the engine bay and under before mounting to chassis
Very busy with work at the moment so have not spent enough time on it......
- Baasvark
- Town: Virginia
- Real Name: Shane
Hey Dean,
How's the project going?
Long time no pics?
Long time no pics?
- dustbuster
- Real Name: Dean
Going slowly , have taken the 4Y out, have revived the 2.5TD from Hoppy and should get the new bell housing next week.
will try to get the engine in next weekend.
- MOFASA
- Real Name: Johno
Must be VERY to see how far you have come since Jan 2011 and still cant drive her....
It should ALL be worth it in the end......
AWSUM build so far.....
Dont loose faith SHE will drive soon....
[rimg=206x128]
[rimg=206x128]
- dustbuster
- Real Name: Dean
Still going slowly, have been tinkering in the garage during my spare time!!!!
Got the body on the chassis and all lined up had to make different size spacers to get the cab as level, so front has 75mm going down to nothing at the back, what I think happened is the mboza glassed the existing rib on the outside of the cab which gave a body lift at the back.
Have the new 2.5 TD engine in place now trying to sort out water piping and intercooler, next is to sort out steering rack and brakes want to mount everything temporally then take off and spray the cab.
Will get some photos this weekend if I can
- 4x4BEES
- Vehicle: Hilux 4.0V6
- Real Name: Kevin
Awesome build boet
You have a lot of patience and determination to keep on going for so long, you must really enjoy it.
Good luck, hope it all works out okay with no further hassels.
- dustbuster
- Real Name: Dean
So in my spare time I have started on the project again , have started designing my bumper and making a mock up one so radiator is in and piping sorted and intercooler is integrated into new bumper and piping is also sorted.
Next is the steering rack fuel system and brakes.
- Vehicle: 2018 FJ Cruiser
Looking good, but you're not doing your approach angle any favours with the I/C in that position.... Can you not lift it, tuck it in closer or even angle it? The WL will perform verry verry nicely with that big IC!!!
email: thysdj@gmail.com
- dustbuster
- Real Name: Dean
Good point will have a look, tricky with trying to get space with the winch and also do not want to restrict the airflow over the radiator.
Will do a side view and see what angle I get with 33” tires on looks a bit funny with the small tires
If you just angle the bottom in towards the back it will already help a lot.
Airflow wont be restrigted too much if you put it in front of the radiator either, but you might have to mod the grille somewhat. On my 2.5 Ford we put a similar sized I/C in front of the radiator with no ill effects..
