Will it be possible to mount a Zara60, that requires a 19mm hole, into a 21mm hole.
The reason i' am asking is, I want to mount the antenna into the original radio's antenna hole. (Not using the sound system).
Thanks.
Z.
Antenna mounting
- Vehicle: 93 Hilux
- Real Name: Z
- Club VHF Licence: HC 117
Antenna mounting
'93 Hilux 4Y EFI
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
Re: Antenna mounting
you'll need to put a reducer ring.
- Vehicle: 93 Hilux
- Real Name: Z
Thanks for the reply, will get one when buying the radio. I am sure our Family dog will be able to help me.Hilux 1 wrote:you'll need to put a reducer ring.
Z.
'93 Hilux 4Y EFI
- Hilux 1
jip, sure he'll be able to
Scott, you can use either a 19mm or a 20mm hole saw. You would have to try it with the (existing?) 21mm hole, chances are that might be a bit shaky. 19mm is a tight fit but the system is designed for that, 20mm works fine but 21mm is something we've never tried - all our hole saws are 19mm. Although it might fit, it might work loose during travelling with the excess movement.
Where is the existing hole - on the fender?
- Attachments
- Repcom Mobile Antennas – Installation Instructions.pdf
- (97.36 KiB) Downloaded 162 times
- Vehicle: 93 Hilux
- Real Name: Z
It's a Jeep Wrangler, on the side of the body. It seems that drilling a 19mm hole is the only way to go.Family_Dog wrote:Scott, you can use either a 19mm or a 20mm hole saw. You would have to try it with the (existing?) 21mm hole, chances are that might be a bit shaky. 19mm is a tight fit but the system is designed for that, 20mm works fine but 21mm is something we've never tried - all our hole saws are 19mm. Although it might fit, it might work loose during travelling with the excess movement.
Z.
'93 Hilux 4Y EFI
