vibration between 80-100kph
- Town: melkbosstrand
- Vehicle: toyota hilux kzte
- Real Name: hein
Hi There
I am new at the forum and just bought a kzte 2001 4x4.I would apreciate any advice as to what the possible cause could be of a vibration on the whole car when traveling at speeds between 80-100kph.
Thanks!
Thanks!
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Re: vibration between 80-100kph
Wheel balancing.
Either a lost wheel weight, or mud on the rims.
Know what you don't know.
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Gaan kyk maar die center bearing. As hy nog reg en vas is kan jy kyk na die universals.
Could be an unbalanced propshaft as well!
- Quintin
- Town: Umhlanga
- Vehicle: Toyota Hilux D/C 2 x Diff lock, 33" MT Tyre, Lexus V8, Winch, Bull Bar and Tow bar.
- Real Name: Quintin
Try tyre presure as well I have it on mine between 100 and 120 if my tyres is on the lower side
- kfxnando
- Town: Germiston
- Real Name: Fernando
its difficult with out actually driving the vehicle!!
have a look and see if the steering wheel also shakes, if it does then one could possibly be looking at wheel balancing!! fronts!!
then have heard of tyres, even brand new tyres that are not perfectly round and no amount of balancing will get rid of it completely!!
then as already mentioned, could very well be a propshaft/s!!
self have a similar problem with the jeep, lucky me still the dealers problem, so I just keep taking it back!! hehehe!!
good luck!!
good luck!!
- Real Name: hein
Thanks guys,I will start to do the faultfinding and keep the site informed as well!!
- Lane
- Town: Port Shepstone - KZN
- Vehicle: 97 Hilux 2.4 D/C Raider
- Real Name: Lane
not sure how true this is but i was told you should wear a loose fitting long pants and if the lower side of the ancle part sways from side to side then its the prop shaft but if the tend to bounce up and down then its balancing or mud etc. makes sence in theory but ive never an unbalanced prop shaft to check.
- the BuTch3R
- Vehicle: '89 Hilux SFA - SOLD; '95 Hilux - STOLEN; '67 Series 2A Land Rover; 3.5 V6 Pajero; 120 Prado VX 4.0
- Real Name: Shaun
I've heard that certain bullbars could also cause an unpleasant vibration at higher speeds due to wind resistance and poor aerodynamics. :problem:
- LouisZ
Check if your front hubs are not "Locked", if they are still on the outside, the red ones you turn if engaging 4x4.
You'd think this would be obvious... but I got caught out recently on a trip... with the hubs locked... and I only clicked when we reached the destination... so check them!4x4megaworldpta wrote:Check if your front hubs are not "Locked", if they are still on the outside, the red ones you turn if engaging 4x4.
I also have that T-Shirt... ;)
- kfxnando
- Town: Germiston
my paranoia has saved me of that one, as I have seen what happens when they are left on LOCK on someones else similar vehicle!!
nasty noises and damage!!
No damage, provided you're not in 4WD as well. It is recommended to drive with them on for about 30km per month in any case, to assist lubrication.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Hein
as jy weer in Kaapstad is, maak seker jy kom by Johann van First Alignment (in Willow Rd, Stikland) uit. Hy is alsoluut fantasties as dit kom by engiets wat te doen het met suspensions en wielbalansering! Nog nie enigiemand wat ek van weet wat al by kom aangelop het vir hulp, was die reggehelp nie. Hy spesialiseer in bakkies en swaar voertuie, so hy sal defnitief kan help.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
