Hilux occasionally does not start - Any advise?
JustinBr
Vehicle: Toyota Hilux 2.2 DC
Real Name: Justin
Post by JustinBr »
Hi
I have a 1993 2.2 petrol DC hilux 4x4.
Recently I have been experiencing some slight starter problems.
When turning the ignition, there is sometimes a slight delay before the vehicle starts. Not always, just sometimes.
Last weekend it didn't start at all. There was no click noise, so I assume the starter motor is fine.
After a quick running start everything is working fine again, despite the occasional delay when turning the ignition.
The battery is rather new (1 year).
What could the causes be? I'm guessing solenoid...But, how do I know?
Thanks,
Justin
No guts, no glory...
LouisZ
Re: Hilux occasionally does not start - Any advise?
Post by LouisZ »
One Question.
Do you have a alarm system with central locking in it?
Hilux 1
Vehicle: 2011 Raider 4x4 Double cab 4.0 V6
Real Name: Tertius
Club VHF Licence: HC137
Post by Hilux 1 »
:shh: :shh: put in some petrol occasionally :surrender: :surrender: :tease:
JustinBr
Real Name: Justin
Post by JustinBr »
4x4megaworldpta wrote:One Question.
No, I do however have a jippo'd security key system. So, you have to push this rod into the holder before starting the car. But, this has been short circuited due to the annoyance factor.
JustinBr
Real Name: Justin
Post by JustinBr »
Hilux 1 wrote::shh: :shh: put in some petrol occasionally :surrender: :surrender: :tease:
Hey, times are tough! :)
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Post by dd6 »
Start by taking out the starter solenoid and just clean and lightly grease the "piston". I once had a sticky starter I sorted out that way, after the starter motor and battery proved to be ok.
JustinBr
Real Name: Justin
Post by JustinBr »
dd6 wrote:Start by taking out the starter solenoid and just clean and lightly grease the "piston". I once had a sticky starter I sorted out that way, after the starter motor and battery proved to be ok.
Ok, thanks. That's the chuck of metal that the positive terminal runs to? My Haynes manual's picture doesn't look exactly like anything in my bonnet...
Mufasa
Town: Bloemfontein
Vehicle: 3.0 D4D DC
Real Name: Barend
Post by Mufasa »
That's correct.......don't know if copper spray will also work?
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Post by dd6 »
Yep, your positive's connected to it. I used a thin layer of multi purpose grease.
JustinBr
Real Name: Justin
Post by JustinBr »
Is the solenoid attached to the starter motor?
niclemaitre
Town: Stellenbosch
Vehicle: 99 IFS DC 4x4
Real Name: Nic
Post by niclemaitre »
Quite often the starter solenoid contacts stop working and the starter then fails to turn. If you remove the solenoid you can bench test it.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
dustbuster
Town: Richards Bay
Vehicle: Rebuilding 91 D/C Hilux Mboza Body, OME 4Y EFI, & 91 S/C 4Y Hilux
Real Name: Dean
Post by dustbuster »
had a similar problem, the 12v wire from the battery was a bit loose on the starter and not making a great connection check that it is nut is tight
