Rear suspension upgrade for 2001 IFS D/Cab
- Town: Gaborone
- Vehicle: 2001 KZ-TE 4x4 DC
- Real Name: Russell
I have just completed a 2-week trip to the Kaokoland with my trusty KZTE. I usually pull a trailer, but this time on account of the expected road conditions I left it behind and loaded up everything into/onto the vehicle. Not sure of total weight, but load included: long range tank, +/-80 litres of water, dual battery system, Onca rear bumper with double wheel carrier, NL 50 litre fridge, Font Runner drawer system, tent, gas bottle, spares, high-lift jack, firewood, miscellaneous camping kit etc, and food for two weeks. Oh yes, beer as well! All went very well, but the vehicle sagged noticeably at the back.
I have the Iron Man springs and shocks fitted, but obviously it still needs to be beefed up a bit more. What experience to fellow Hilux owners have with Loadhogs or similar "helper" products?
Most grateful for any advice.
A bad day in the bush is better than a good day at the office.
Triton 3.2 4x4 D/C A/T
2001 KZ-TE D/Cab. SAC Intercooler & chip. Nudge-M. Iron Man Suspension. Long range tank. Dual Battery. 29mHz. BFG A/T. etc (Reluctantly left behind when I left Botswana).
Re: Rear suspension upgrade for 2001 IFS D/Cab
Hello Russel, and welcome!
I cannot give you first hand experience advice since I've never made use of such accessories .... only what I have been led to believe. Most of these products do what they are intended for to some varying degrees, but I believe the general consensus to be that they hinder or impair off-road capability. This is however not a major consideration for over-landing trips such as what you've just mentioned ... I mean you're not necessarily going to tackle a lot of obstacles. I would then consider something that is easily removable after a trip, like for example the Camil coil over shocks ... (don't really like their products personally). They can be quite easily replaced with the standard shocks after a trip .... 4 bolts only. Alternatively the 'LoadHogs' or whatever your preference. IMO these are still better options than fitting extra blades to the leaf packs which would result in a hard ride when not loaded.
Best of luck with your choice.
- Niel
- Real Name: Niel
I had a set fitted for that very reason, to carry the extra kg's and to date I had no problems not on tar or on gravel. Done the West coast echo route and carried kit for 7 days very little to no sagging. What I like about it is that should you do obstacles you can remove it in a few min.
viewtopic.php?f=4&t=11629" onclick="window.open(this.href);return false;
Niel, I don't see a reference in that thread as to what suspension aide you fitted?
Russel, do you know which Iron Man 'packs' you have fitted, there are three different types?I have the Iron Man springs and shocks fitted
- Niel
- Real Name: Niel
dust-devil wrote:What experience to fellow Hilux owners have with Loadhogs or similar "helper" products
Load HogsMud Dog wrote:Niel, I don't see a reference in that thread as to what suspension aide you fitted?
OK Russel, ... there you go! Niel likes RoadHogs ... has tried them and is satisfied with their performance. Also easily removed when not required.
- Town: Gaborone
[/i]OOOOMS wrote:Russel, do you know which Iron Man 'packs' you have fitted, there are three different types?I have the Iron Man springs and shocks fitted
AFAICR its the Sport (?) kit (not the Load Carrying kit).
Then you will have to fit 'heavy duty' blades, as adding extra leaf pac's will only be a temporary sollution.
The 'medium' blades are not designed to carry heavy load and you run the risk of breaking.
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
This is interesting reading, that you can remove Load Hogs as needed does have it's advantages.
That might be something to consider when bringing back loads of meat from a hunting trip.
Know what you don't know.
- michael01
- Town: Gauteng
- Vehicle: 1995 Hilux
- Real Name: Michael
Why don't you try a set of air bags at the back? Lots of people like them even soften the ride for you and doesn't really affect off road proformance. Just my 2cw
Yes for sure Heinrich, also had a good look at em some time ago. Not to run down any previous comments down as I do believe they can work.
But like any equipment, if abused they do break. In fact, the day I was at the fitment centre a vehicle came in with one broken. Not sure if it was abuse or not.
- Town: Springs
The biggest reason I've never considered them seriously has been because of the very harsh ride they can give when not loaded as well as the loss in articulation which you do get without a doubt.
Michael, airbags will be my first choice, but cost if kind of constricting on them.
Air helpers have there advantages and disadvantages.michael01 wrote:Why don't you try a set of air bags at the back? Lots of people like them even soften the ride for you and doesn't really affect off road proformance. Just my 2cw
Firstly the cost around R4.5k (leaf springs) coils are cheaper R2.5k
Load-hog around R1200 last time I heard
Air helpers do not 'give' when driving through ie axle twisters. You also stand at rist when driving at parculiar angles 30 to 40 deg of rolling the vehicle.
For towing and load the air helpers are fine and convenient
